you can change a lot and ‘it will work’, but it won’t necessarily cover a full
sheet of plywood well. As you lower the top beam, it becomes harder to cut along
the top (especially in the center)
the spreadsheet is at
Brilliant and very handy info. Thank you.
Very helpful. Thanks.
Lest there be confusion, the spreadsheet links that @dlang and I posted are the same.
The bolt on frame is complete with the original dimensions but lowered to fit into a caravan. The motors have been fitted. The chain and arduino have also been fitted. I’m up to the temporary sled. All screws found for the motor.
