Just about done! Just one tiny frame related question left
I’ve pretty much finished my maslow, after much procrastination!
I had some issue putting together my frames, while they are identical I’m certain that they ended up a different angle from the original design. Is there a certain angle I should be aiming for?
that’s a subject for debate right now :slight_smile:
the stock design is ~15 degrees from vertical, but some people are running 7-10
degrees from vertical, it hasn’t been extensively tested (by anyone, the
original design was “that looks reasonable”)
I’ll have to check and see where I ended up. I’m thinking 7-10 degree camp.
Nice build, but that UFO that circles around your house is a bit freightening.
If they can build UFOs then they should be able to calculate the perfect angle and solve chain sag math
It’s a seasonal UFO, mostly around during the Christmas season.
Going to be cutting out some candy canes with the maslow to put in the front yard as decorations to appease them.
RPO Reindeer powered object, from the softdrink factory…
