In the gcode given for the final sled design, what size tool bit is used? I am guessing quarter inch.
Which file are you using?
The one from the assembly instructions. Already cut it using a quarter inch bit, but it would be nice to specify in the instructions.
Good suggestion. I’ve renamed the gocde file to indicate the bit size in pull request #4. I didn’t change it in the instructions because if you are generating your own gcode from the .svg files you can choose any bit size
