It seems that we always ask for the log file whenever people run into issues that we try to solve.
Would it make sense to create a parser for the log file? It could implement several features for analyzing the log file. I would implement it as a online tool for people to upload their file to and get feedback on.
Brainstorm thoughts:
Output a gcode file from the log (Would that even be possible?)
Warn about decimal resolution being to “high”
Output where the “buffer” keyword is found, including the previous / next 5 lines for each hit.
Let me hear what you think about that. I would be able to create a proto type of the this to show of, before we spend to much time on it.
Why do we need the constant out flow of:
[PE:0.09,0.19,64]
<Idle,MPos:33.51,2.86,-13.00,WPos:0.000,0.000,0.000>
It’s kind of annoying testing grbl compatibly and checking the logs, plus creating a huge log file.
We either need a simpler log file, only containing the information we need to troubleshoot or we need some tools to help us doing the initial analysis.
Theoretical via script, yes.
Challenges: To catch “sending” as well as “ending” with the missing ‘S’ and the lines with gcode that don’t have a sending or ending in front. From a linux perspective all tools needed are installed by default.
Edit: sure this can be done via batch on window as well
Still had to remove a lot of text like ‘turning spindle of or on’, ‘not supported and ignored’ and other stuff.
The buffer overflow needed to be removed. Looks good from a quick view, but has issues. No time left today. loggcode.nc (127.4 KB)
we don’t know what info we need in the file until we have a description of the
problem
What about 2 log files?
what do you put in one rather than the other?
issues tend to come is bursts, we start having people run into a problem, we
diagnose it and implement a fix, and that problem stops showing up as much.
