I unfortunately just don’t have the time to learn how to program and debug Fusion360 to gcode and could use some support. Is there anyone out there that can help on a per project / per hour basis to get our drawings ready to run through our machine?
We are trying to use our Maslow for the business to do some signage cutouts for weddings and events. Generally our needs are fairly simple - national park-like signs, large san-serif letter cutouts, monograms, and full size panels with a repeating image cut out - but i want to see if I can use this machine reliably. In general we are using 1/2" - 3/4" plywood/foamcore/gator foam. I’ve done some basic calibration, but beyond that haven’t been able to load anything in to fully test it.
If all you are looking to do is signage, and your designers are pumping out the svg files for you, try looking into Easel or Esltcam. It is super simple to use (not anything like trying to figure out F360), and as far as I know, both allow you to just drop in the svg, and then select what cutting operations you want, export the gcode, load to GC/WC/Makerverse and off you go! Both do have a cost (you can get upgraded to Easel Pro if you are in the education field teacher or student for free) and Estlcam was $60 the last I looked at it. Just an option to look at, particularly if you, again, are only looking at making signs.
