If anyone is looking for a test file to run, here is the M logo. It’s designed to be cut from 1/4 inch plywood, but as a practice cut you can cut it into your spoil board or even run it without the router bit in.
SD_maslowdoorsign.nc (26.8 KB)
Oh come on! You all knew I would.
The less KB version - GCodeClean --minimise medium version
SD_maslowdoorsign-gcc.nc (16.8 KB)
