I’m new to maslow. I cut one of my belts in half after it was damaged. I ordered a replacement but in the meantime can i still calibrate and cut if one belt length shorter? I also have the issue where when i click calibrate it unspools the belts completely and goes as far as to wind them tight the opposite way (flat side facing out). I will keep searching on the forums for answers, but if anyone could give advice because I’m very uncertain how to troubleshoot.
Just got my full 4.1 kit a couple days ago. unfortunately my belt got jammed while unspooling during calibration. I believe I deformed it further trying to pull it out. so I disassembled it, cut the belt at damaged area and reassembled.
I’m having trouble calibrating it. I think it is stuck at step 4 to six. idk how to know if the calibration is complete or i should retry
Serial Messages
Index.html Version: 1.03
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:bernie&yoko]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.0.50]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
JogTo: '$J=G91F300Z5
error:8 - Command requires idle state. Unlock machine?
[MSG:INFO: Caution: Unlocked]
JogTo: '$J=G91F300Z-5
Retract All
[MSG:INFO: Requesting state change from 0 to 1]
[MSG:INFO: Top Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
[MSG:INFO: Bottom Right pulled tight with offset -2.770]
[MSG:INFO: Requesting state change from 1 to 2]
Extend All
[MSG:INFO: Requesting state change from 2 to 3]
[MSG:INFO: All belts extended to 1700.000mm]
[MSG:INFO: Requesting state change from 3 to 4]
Calibrate
[MSG:INFO: Requesting state change from 4 to 6]
[MSG:INFO: Machine Position found as X: -15.631 Y: -111.303]
[MSG:INFO: Center point off by: TL: 0.000 TR: 0.000 BL: -968.909 BR: -1570.365]
[MSG:ERR: Center point off by over 100.000mm]
[MSG:INFO: Frame size automaticlaly adjusted to nan by nan]
[MSG:INFO: Machine Position computed as X: nan Y: nan]
[MSG:INFO: Measuring Frame Flex]
[MSG:INFO: Flex measurement: TLBR: 0.656 TRBL: 2.041]
Yes, as long as the belt will reach the anchor from the far corner of your
workpiece, it doesn’t matter how much more is on the spool
ended up downloading a new yaml and updating that. after that ive been able to calibrate. i also switched to vertical orientation which helped with not having as much slack during failed calibrations. still when i was figuring stuff out i managed to break my belts multiple times. I’ll have to order a 2nd replacement belt to do full sized cuts
