M4 Accuracy? Say on a straight line of 60" how straight is it, best case and worse case?
I have two earlier versions, Maslow and Makermade using RPI4. Can anyone tell me how accurate M4 is when ciutting a straight line of say 60" or more? What is the deviation?
Also, most importantly can I stop and resume cutting without nicks or divets in a cut. For example if I want to cut 24x36 cabinet doors. Mahogany veneer plywood is now over $100 sheet. I cannot afford any mistakes
I was not able to do that before.
Also, on the Z axis, what is the range (depth) of the cut?
I think you would be better off using a track saw if straight lines is important.
It’s going to depend on how rigid your frame is and how accurate your
calibration is. We have not had a lot of people testing this
there is about 2" of spindle travel possible, but only some of that will be
useful, it depends on your bit.
