Ok, so I’m part way through the assembly of my M4 and I must say as someone who has assembled some very delicate and wild pieces of equipment (Ex Mechanical Technician of CERN for the LHC) this has been a fun and challenging build.
A few suggestions, notes, etc.
The instructions, in many steps, don’t state which nuts should be locking nuts and which are normal, I’m nearly out of normal having only used mostly those and very few locking.
Speaking of nuts, the hexagonal holes could be a little smaller to allow for a nice push fit and not easily pushing the nuts out when holding with one hand and trying to screw in with the other, thought these hexagonal holes do make things easier with only having one set of hands.
Not sure why but my instructions loaded weird and i ended up screwing the small “ethernet” board to each of the tape arms instead of adding the stepper motor first, i was more reading than looking and a step missed while loading on my instructions. Needless to say this created a whole 2 hours of trying to remove the screws with loctite unsuccessfully and finally drilling them out very carefully.
Due to this and the difficulty of one pair of hand assembly, I would suggest a modification where the board is screwed to the stepper motor and then the board screwed onto the arm.
The tape, I had to unravel it from.the bags and then reravel onto the “cartridge” to glue them, it would be nice if a small clip or something was included to prevent them unravelling while the glue is drying and during.assembly.
Also the “2nd hole” for the tape to pass through is rather confusing when passing the tape bewteen the rollers at first i struggled to get through one hole and then realised it was the other.
The cartidge order during assembly seems to be different in the gif to what is written above it in the instructions.
The instructions state power cable down then assemble upper left, lower right, upper right and lower left, but the gif shows the cord the the right and then assembled in the order of upper right lower left, upper left, lower right (based on the cord location not the angle of the gif).
It.mighr be easier as you state the notch of the ring positions where the cord is on the motor that you number around the ring, 1, 2, 3 and 4 for the assembly positioning.
Also @bar can you clarify which on the instructions is correct please ![]()
Also how did you guys get them reeled up so much in the gif? I dont think there is enough space between the pin for the gear and the tape itself on mine.
When assembling the 4 legs (2 with bearings) I suggest to use the hex key provided, put throughnthenhole from.the outside in and slide the nuts down into place (I used the locking nuts) carefully slide the screws through and twist to just grip the nut x3 and then in one hand hold the 2 parts at a distance from each other while making 2 or 3 turns on each screw and gradually pulling the 2 parts together - I took a picture but not sure how to upload
Lastly I personally would suggest a T8 Torx or Hex Key bit with ratchet screw driver for assembly, i have a Kobalt one that had a ratchet grip which acts as a double drive, it made only having 2 hands a lot quicker. - also have a pic it it is of interest and helps.
Thanks in advance for any feedback. I wont be continuing till hopefully the order of cartidges is confirmed and may have further tips when finished.
