Using Makerverse over the weekend I observed that my z-axis is cutting deeper than cuts done with previous frontends. My I inquire what settings others are using with the primitive z axis using the Rigid Router adjustment screw. Here are mine:
max z axis RPM 12.6
Z-axis distance/rotation 3.17
A-axis steps per revolution 8640
Looking at other posts, the 3.17 appears correct, maybe the 8640 is the problem.
If the settings are correct, it is likely user error in the touch probe widget.
Thanks
