Hi,
I’ve designed this necklace pendant and I can cut it just fine, but now I’d like to make as many as I can fit on a sheet 1000 mm x 600 mm. With it’s cad vectors it should copy all the settings, including the whole cam set up.
When I use the move/copy command, it seems to only make independent copies, so if I would make a change to the vectors or cam for the one part it would not make it for all of them.
There is a way to do it, but not sure how. I’ve watched a video (https://www.youtube.com/watch?v=yvCHb3DRNrw), but I’m not sure I understand, at least I was not able to replicate (ha!) it.
Any suggestions?
