Maslow 4 3D printed parts thread
Probably. I used making tape to hold them to the belt. I’m going to shorten the tails when I reassemble the arms.
I’m going to go one step further after disassembly and reassembly and say that @RandomDave is likely correct. The one arm that didn’t have a broken roller had the shortest and best secured tail. I don’t know if there was interaction with the amount of force previously required to rock the belts loose during extension.
With the main topic of the thread, I did a linear rail conversion of my Maslow as part of some experiments, started detailing it in this thread:
I linear rails-ed my Maslow
(rather than repeat it all here).
Updated step file using spring from clickable pen
PencilLeadHolder.step (219.2 KB)
Turtle Clamp design I came up with:
Turtle Clamp (non-split clamp design)
But also note, new directory as part of @wouldchuck 's work:
Not my work, just pointing towards it.
I mean your work organising / compiling things :slight_smile:
Adding to some of the other plotter options in this thread, I made an 3D printed attachment for a mini sharpie that holds it into the spindle when you remove the collet. Not spring loaded, but stiffness of the marker tip seems to be low enough that you can just preload it with the z-axis when you set the zero.
miniSharpieMaslow.step (228.3 KB)
Cool and simple.
Sorry if this was mentioned but what material/filiment are you using
thanks
I just used PLA, nothings heat critical, so I don’t think it matters much
Hi, I visited your store and I’m interested in a few things, but I have a question: do you have the pins for the anchor points? I’m also interested in the anchor points and the dust collection piece.
I dont carry the pins, but you can find them on Amazon. These should work fine:
What size dust collection are you looking for?
I would have to check the vacuum cleaners available in my country to see the hoses, and one more question: do you ship internationally?
I could. I would just have to get a quote based on the size and weight of the box before I could give you a price.
