This is a companion discussion topic for the original entry at http://maslowcommunitygarden.org/Maslow-CNC-Kit.html
There was a request for a complete list of parts with links so I’m creating one here
some of the parts listed in the BOM are wrong.
| Part | # Included | Source | Alt Source |
| Cotter Pins | 2 | fastenall | |
| Brick Mounting Bolts | 4 | fastenall | |
| Brick Mounting Nuts | 4 | fastenall | |
| Short Wood Screws | 14 | fastenall | 7000bulk box??? change to part # 32182 individual screws |
| Long Wood Screws | 90 | fastenall | 2000 bulk box?? change to item # 32187 for individual screws. |
| Motor Mounting Screw | 8 | fastenall | |
| Motor Mounting Washer | 8 | fastenall | not washers, duplicate of above bolts. |
luckily it’s pretty easy to spot the errors because your shopping cart becomes extremely expensive.
Great catches! I’ve created pull request #3 to propose fixing those part numbers
also… what do we do about the “custom” parts that are listed on the BOM?. are there PNs or plans for making them?.
Brackets
|Ring|1|Custom||
Electronics
|Z-axis Motor|1|Custom||
|Motor Cable|2|Custom||
|Z-axis Cable|1|Custom||
Other
|Elastic Cord|2|Amazon|| ---- What diameter and length?, there are options on amazon
|Chain|2|Custom|Amazon| ---- length?..
|Motor sprocket|2|Custom||
|Slack Sprocket|2|Custom||
|Heatsink|2|Custom||
|Ring Bearing|4|Custom||
Brackets
Ring>1|Custom||
there are two linkage kits available that can do the job
Electronics
there have been lots of discussions about motor options, I won’t try to cover
them here.
Other
it varies, with recent setups (counterweights), we don’t use this except for the
anti-backlash on the Z axis
Chain>2|Custom|Amazon| ---- length?..
I believe that stock in 11’ each, but you would do well to get ~13’ each in case
you end up wanting to extend your top beam
8mm inner diameter, 10 tooth #25 roller chain sprockets
a #25 sprocket with no hub
Heatsink>2|Custom||
newer motor control boards come with heat sinks
only needed if you are doing the ring rather than one of the linkage kits
So where on this website can I actually buy the CNC? I must be missing it somewhere.
There are a couple companies selling kits right now, metalmaslow just started
selling their upgraded kit, and makermade is selling the original kit.
You can find links to all of the options here:
