I am running a Mega 2560 with 51.28 firmware and Makerverse 1.1.3 running on Winows 10. I load an .nc file and when I press play, the sled moves to starting position, lowers the router and then stops. The following is in the console window and the Abort error is in a read box in the upper screen. I can’t seem to find a solution. It happens with any file I load. I can jog the sled to anywhere on the board. Any ideas?
Any file I tried. The sled would move to the starting position of the cut, plunge the router and then stop. I wiped my EEPROM tonite and was going to recalibrate tomorrow. I will keep you posted. Thank you!
bar,
I wiped EEPROM and loaded the firmware. I deleted my workspace and created a new workspace. Got it calibrated to 3MM and called it good. I loaded your file and it cut with no problem. I moved to a different space and it cut fine. I created a 200MM file. It cut 100mm and then came up with the error from before. I have attached both a text file of the console and the nc file I created. I dl the maslow logo from the garden and it cuts until the first direction change, I dl fold flat chair from the garden and it moves to start, router goes down, cuts a small circle and then stops
my thought at the time was that you were having a z-axis binding issue. i was suggesting that you manually move the Z up and down to see if it was binding. since then though you determined that that is probably not the case because you were able to progress beyond the point you were getting the fault. My suggestion is now probably moot.
I’m not sure that I have actually seen this error message before so it might be a MakerMade thing. Is it possible to try with WebControl? I’m getting a bit out of my area of knowledge here.
I’m having the exact same problem here. This is the first program i have run since i moved and recalibrated with makerverse. Webcontrol was on another machine, which ran okay but because there were some improvements with makerverse, i shifted to that. I used estlcam to generate the .nc file. looks all okay. I am hoping there is an answer.
