How we should measure distances accurately.
On the right to right of the cut,
This approach is the best. Since errors of a fraction of a mm make a difference
here, trying to estimate the center of a cut/mark doesn’t work, and right to
left require you to know the exact bit size.
All my measurements were made with laser and a block of wood located in the center of the mark.
you would be better off with a metric tape measure, with it you can get an accuracy of around 1/2 mm
the accuracy benchmark was made with the squares just under 6" so that you could use the $10 digital calipers from Harbor Freight (or similar), but for the calibration, we need to measure longer distances, so you would want to use a metric tape measure and make your best effort at sub mm accuracy (you should easily be able to get 1/2mm, and if you are careful, you should be able to get to 1/4mm)
±1.5mm is bad enough to throw off the calibration results.
Wow, 1,5 mm accuracy, that’s good if you’re measuring a room, but totally useless here. The cheapest callipers get 0, 1 mm accuracy if you know how to use them.
Seems like there you have a tool that gives you high resolution to fake high accuracy. I hate when they do that.
Edit. ±1,5mm that’s 3mm of inaccuracy
Thanks for sharing DXF file! Is that PMMA (aka Acrylic) 1/8 inch or 1/4 inch thickness? And if you have the pre-configured g code to also share, many would love to see you submit everything in the Maslow Community Garden
