It will do some nice letters but when I try to cut out a square or rectangle to cut the sign out, the whole shape is tilted. It will not cut at a 45 angle with the board I’m cutting.
is it climbing because the feed rate is too high and the bit is dull or is the chain catching and the sled not sliding?
I am getting pretty nice cut within 18 inches of center. Anytime I get further out than that everything is tilted.
this is a common issue, you have to make sure your sled is in center and check home?. I think in the new version of makerverse it is called reset chains? I dont’ use the software, but have read about this issue severla times my terminology might be wrong.
