Anyone else having trouble with version 0.78.1?
I’ve spent about 10 hours calibrating in the past 2 days. Starting with … can’t remember the version it was shipped with, then with 0.77 and finally with 0.78.
Most of this time I forgot things, like the yaml file, or to release tension before I powered down the maslow4, etc.
I don’t have the router installed, just a marker. On version 0.77 I marked out a 150 x 150 square and the inside is 148 x 148. Maybe the marker is wider than 1/8 inch. Looked good so I upgraded to version 0.78.1 and it won’t calibrate - refer below for all the logs I could get (or that I think I can get)
Version 0.77
Machine width 3884
Machine Height 2642
Calibration grid 1000 x 1000
grid size 9x9
retraction force 1000
As the calibration moves through the different grids, width moves to 3884.8, 3884.7. Height moves from 2642 to 2641.5 to 2641.8 to 2641.7
Log from the attempt to calibrate with 0.78.1
Serial Messages[MSG:INFO: Channel auto report interval set to 50 ms]
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0][MSG:INFO: FluidNC v3.6.7 (Bringing-in-Maslow-changes-bit-by-bit-b659ebef-dirty)]
[MSG:INFO: Machine Default (Maslow S3 Board)]
[MSG:INFO: Board Maslow][MSG:INFO: UART1 Tx:gpio.1 Rx:gpio.2 RTS:NO_PIN Baud:115200]
[MSG:INFO: Axis count 3][MSG:INFO: Axis X (-2438.400,0.000)][MSG:INFO: Motor0]
[MSG:INFO: Axis Y (-1219.200,0.000)][MSG:INFO: Motor0][MSG:INFO: Axis Z (-100.000,0.000)]
[MSG:INFO: Motor0][MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.110]
[MSG:INFO: Motor1][MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO_PIN R:0.110]
[MSG:INFO: Z Axis driver test passed][MSG:INFO: Z2 Axis driver test passed]
[MSG:INFO: Using spindle NoSpindle][<Alarm|MPos:0.000,0.000,-46.000|FS:0,0|Ov:100,100,100>
[MSG:INFO: Compiled with ESP32 SDK:v4.4.7-dirty][MSG:INFO: Local filesystem type is littlefs]
[MSG:INFO: Configuration file:maslow.yaml][MSG:INFO: Machine Default (Maslow S3 Board)]
[MSG:INFO: Z Axis driver test passed][MSG:INFO: Z2 Axis driver test passed][MSG:INFO: Kinematic system: Cartesian]
[MSG:INFO: Using spindle NoSpindle][[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started][MSG:INFO: WiFi on][MSG:INFO: Captive Portal Started][MSG:INFO: HTTP started on port 80]
[MSG:INFO: Telnet started on port 23][GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0][MSG:INFO: Retracting all belts]
[MSG:INFO: Bottom Right pulled tight with offset -1970.640][MSG:INFO: Bottom Left pulled tight with offset -2254.857]
[MSG:INFO: Top Right pulled tight with offset -2233.599][MSG:INFO: Top Left pulled tight with offset -2423.542]
[MSG:INFO: Center point deviation: TL: 0.278 TR: 0.224 BL: 59.042 BR: -3.538]
CLBM:[{bl:2407.99, br:2346.46, tr:2349.59, tl:2351.11},
{bl:2281.08, br:2282.20, tr:2490.44, tl:2430.54},
{bl:2175.66, br:2401.78, tr:2585.65, tl:2324.37},
{bl:2303.94, br:2453.32, tr:2453.84, tl:2248.81},
{bl:2374.35, br:2521.74, tr:2388.95, tl:2177.83},
{bl:2475.93, br:2422.54, tr:2281.57, tl:2283.99},
{bl:2580.22, br:2323.59, tr:2176.17, tl:2391.25},
{bl:2453.34, br:2247.95, tr:2314.80, tl:2452.77},
{bl:2388.44, br:2176.85, tr:2395.06, tl:2528.15},]
Computing… This may take several minutes
Fitness: 0.4811558 in 100
Fitness: 0.6506239 in 200
Fitness: 0.6908420 in 300
Fitness: 0.6918169 in 400
Fitness: 0.6918169 in 500
Fitness: 0.6918169 in 600
Fitness: 0.6918169 in 700
Fitness: 0.6918169 in 800
Fitness: 0.6918169 in 900
Fitness: 0.6918169 in 1000
Fitness: 0.6918169 in 1100
Fitness: 0.6918169 in 1200
Fitness: 0.6918169 in 1300
Calibration complete Calibration values:Fitness: 0.6918168854791233
Maslow_tlX: 85.4Maslow_tlY: 2642.0
Maslow_trX: 3956.3Maslow_trY: 2642.7
Maslow_blX: 0.0Maslow_blY: 0.0
Maslow_brX: 3972.5Maslow_brY:
0.0A command to save these values has been successfully sent for you. Please check for any error messages.
[MSG:ERR: Unable to move safely, stopping calibration]
I checked the configuration -
The config has been cleared. Width blank, height blank, calibration grid width and height are blank, 9x9 is still there, Retraction force is blank.
TEST button shows me index.html version 0.78
Power cycle to Maslow4
Width is now 3956.3, height is now 2642.7, horizontal, 1000 x 1000, 9x9 grid, retraction 1000
So it DID save the values, but maybe they didn’t reload so the calibrate could not continue?
Width 3956 is too high. When I run the calibrate again the fitness is too low and fails.
Anything else I can capture to help track this down before I revert to 0.77?
