This is a companion discussion topic for the original entry at http://maslowcommunitygarden.org/Max-from-The-Grinch.html
I can’t edit the original files so I will upload the changes here. I went ahead and drew the borders all the way around. Here they are in this update. Max.zip (122.8 KB)
This is just a sample of the real image.
Here is the Grinch as well. I took a photo that has the best layout and then loaded it into inkscape. I created different levels to draw over the main object. I used the bezier curves and just followed every path around the character. In the file is different levels of progression so that you can pick up anywhere in the project to alter to whatever you want. The original file.
The file after drawing it out by hand.
The svg files. Grinch.zip (374.4 KB)
