My router base mechanism binds up solid if I raise my height just over .75" (shitty!). But it is what it is until I can cut out my new Z setup.
So I need to set my Z Raise limit.
( If the Z travel goes further (Higher) than that, it seizes up, on the way up, and I have to take apart the entire Bosch base in order to free it up again, or further Z travel is impossible, and the motor burns up.)
It’s bad!
Well maybe you can help me figure this out.
(You’re always super helpful, thank you.)
When I open up the Z axis control pane, I’m able to set my zero (just 0.1 to 0.5 mm from touching the wood surface) after that I’m able to raise my z, and return to zero no problem, but when I go to the calibration page, and go to “Adjust Z Axis” after doing this successfully, I press “Define Zero” the bit raises with no stop button in sight, and proceeds to jam the router up into the base.
is it moving to safe z axis height after zeroing? What is that height set at? Are you in mm or in? Is your z axis pitch correct for mm moved per revolution?
