I’ve calibrate the z axis zero point just above touching the wood and it doesn’t plug all the way through on a cut out.
But yet if I zero just on the wood it cuts all the way through, but it drags the wood as it travels not on the cut paths.
What settings am I missing? Or did I calibrate it wrong?
Also I adjust the safe travel height to 25mm but it doesn’t seem to do anything during the g-code.
Also I’m using easel for my g-code.
I’m done the router bungie to assist z axis motor.
