David, et al
Thank you for the very helpful information. Lots to think about…
I’ve been thinking a lot about the configuration and calibration, particularly saving calibration settings to nonvolatile EPROM. For some reason it appears that successive attempts are supposed to improve the accuracy–this may stem from the Holey calibration?? I’m not sure. I think that this is a problem. It should be set once correctly and be saved–and not changed until there is a modification to the device or there is significant wear on the components. Otherwise it is a moving target. If successive approximation is required, there is something wrong with the design–it has too much play. Please correct me if am wrong in this assumption. If you have ever done timing on a car engine–similar to calibration on the Maslow. You do it once. If it is set correctly and you don’t need to change it unless there is wear or a some modification. This is a simplification of a very complex process, but you get the idea. I stand by my statement that the sled should always go to 0,0,0 every time when you hit the home button.
Back to the problem of the stuttering. I am going to try both slowing down the movement, and reducing the back pressure from the spring that is attached to the chains (I’m using a 16" spring with the original cog gears). Now that I have increased the top beam to 12’, I think that additional width has increased the spring tension which may be adding addition force (load) to the motors making them work harder.
Also my sled has a linear slide with a ballscrew which is rather heavy (26#'s). I had factored this into the calibration, but it may be a bit too heavy. I have added an HDPE ring under the sled to reduce friction.
I’ve been toying with the idea of adding drag chains to add additional ‘pull’ into the lower corners.
Please see the attached photo of a working model using plastic chains and gears. I’m not sure this will work but I’ve found, as you’ve said, that there is very little force in the lower corners. My intention is to be able use the full 4’x8’, possibly even 4’x10’ to create my arc templates.
The lower chains in the ‘model’ will be spring loaded. I’ve found that I would need a rather long pair of chains. As you’ve said most force will be required in the lower corners. I need to figure out how to only add enough spring force to complement to motor chains and not over power the upper corners. There are other concerns with this approach such as replacing the work-piece, but this is not significant
Looking forward to your thoughts.
I’m hoping the stuttering is easily solvable. I will work on it tomorrow.
The endless calibration is a continual annoyance.
