I’m super new to all of this and I’m having the same issue. I got the original maslow and ordered the M2 kit and set it up from the start with this.
Everything is hooked up, measured and inputted.
The sled will move left and right and the z will raise and lower fine but the Up and down controls for the sled are inverted. Can’t seem to figure out what all the $$ options do.
$0=10 (Step pulse time, microseconds)
$1=25 (Step idle delay, milliseconds)
$2=0 (Step pulse invert, mask)
$3=4 (Step direction invert, mask)
$4=0 (Invert step enable pin, boolean)
$5=0 (Invert limit pins, boolean)
$6=0 (Invert probe pin, boolean)
$10=1 (Status report options, mask)
$11=0.010 (Junction deviation, millimeters)
$12=0.002 (Arc tolerance, millimeters)
$13=0 (Report in inches, boolean)
$20=0 (Soft limits enable, boolean)
$21=0 (Hard limits enable, boolean)
$22=1 (Homing cycle enable, boolean)
$23=0 (Homing direction invert, mask)
$24=250.000 (Homing locate feed rate, mm/min)
$25=500.000 (Homing search seek rate, mm/min)
$26=250 (Homing switch debounce delay, milliseconds)
$27=1.000 (Homing switch pull-off distance, millimeters)
$30=24000 (Maximum spindle speed, RPM)
$31=4000 (Minimum spindle speed, RPM)
$32=0 (Laser-mode enable, boolean)
$40=22528
$41=17408
$42=20480
$43=5000
$50=22528
$51=17408
$52=20480
$53=5000
$60=20480
$61=17408
$62=18432
$63=5000
$80=0
$81=2438.400
$82=1219.200
$83=3400.000
$84=427.000
$85=1.004
$86=1.003
$100=127.775 (X-axis travel resolution, step/mm)
$101=127.775 (Y-axis travel resolution, step/mm)
$102=472.500 (Z-axis travel resolution, step/mm)
$110=1000.000 (X-axis maximum rate, mm/min)
$111=1000.000 (Y-axis maximum rate, mm/min)
$112=250.000 (Z-axis maximum rate, mm/min)
$120=25.000 (X-axis acceleration, mm/sec^2)
$121=25.000 (Y-axis acceleration, mm/sec^2)
$122=10.000 (Z-axis acceleration, mm/sec^2)
$130=2500.000 (X-axis maximum travel, millimeters)
$131=1250.000 (Y-axis maximum travel, millimeters)
$132=25.000 (Z-axis maximum travel, millimeters)
ok
And on a side note, when I unlock it to enter my offset, the terminal will show the updated settings but not the GUI. Maybe it’s just cosmetic.
