- Your Operating System with version (Windows, Mac, Linux): Windows 10 64-bit
- Firmware and GroundControl version number you are using: FW 1.26 - CG 1.26
Temporary frame/sled or final build : FInal - Z-Motor installed or manual Z adjustment: Yes
- Chain mount system to the sled (Original brackets or a Triangular Kit): Triangular
The problem: just installing my Maslow which set in its box for over two years, build the frame and mounted the motors and controller, upgraded the firmware to the latest version (1.26) plugged in my computer started GroundControl version 1.26 and I can not get the motors to move, they don’t even make a sound. checked everything at least three times and all connections are correct and tight, but the motors still don’t move. Where should I look next to fix this problem
