all my belts other then one are not retracting i just swapped out my pcb calibrated and it was working well i took some time to modify my Gcode and when i came back to extend the belts they stoped funtioning .
when i push on them
I’m not quite sure I understand what you are saying. Can you describe what is going on in a little more detail?
oh it seems like part of my post did not send
3 of my belts won’t retract i found on the forms this link and it seems like that my same issue
https://forums.maslowcnc.com/t/m4-cut-fail-not-much-info-but-potential-z-axis-bug-after-stop/20829/44
Are you seeing the behavior where when you push on the belts they are extending instead of when you pull?
yes that does seem how it is behaving
That for sure sounds like the same issue. Does soldering the encoders like this feel like something you want to do?
If not DM me your address and we’ll ship you some that have already been soldered!
i can solder them and update you on the status if there is no change ill reach out thank for confirmation i just wanted to be sure before i started diggin in
