says top right encoder is not found, has a orange light next to the green by the motor
Try unplugging the cable to the top right encoder and plugging it back in. Itās probably a connection issue
Iāve tried unplugging it, and restarting it, bringing the belt through the gears makes the orange light turn on and off, and there is also a red light I forgot to mention is flashing on top, also is the top right the 2nd one from the top on the stack of arms or just the one with the light on it?
Great question, top right is in relation to the power cord being down so if the power cord is facing you itās the one on the right which is further away.
the red light indicates that there is an error. If you run a test and it says it
canāt talk to an arm, that is probably a connector problem, unplug the ethernet
cable, blow any dust out of the connector, and plug back in solidly. Once you
get good connectivity reported from the test button to all encoders, hot glue
can help prevent them from causing problems going forward.
Thank you for clearing that up for me, I figured that was probably how it was setup but just wanted to make sure
Oh okay, thank you for letting me know that, and Iāll try and disconnect it a few more times and fidget with it some more and get back to you on how it goes, also would you mind telling me also what is the orange light on the encoder means?
The encoder should have two lights, the green light shows that it has power, and the orange light will get brighter and dimmer (to the point of being all the way off) based on the encoder position so as the magnet rotates you will see that one change
Iāve messed with the Ethernet cords more now and switched them out but it still hasnāt cleared the error code
If you are still getting the āencoder not foundā switch the cable to a different
encoder and switch a different cable in as well, see if the problem follows the
cable or the encoder (or stays put)
that will tell us if itās a main board (doesnāt move), encoder (moves when you
plug the encoder in elsewhere) or cable (moves with the cable)
I switched which encoder it was plugged into and then switched the cords and tested with different cords and it still said the same error the whole time
Ok, that sounds like a bad board, @bar
Like it always says ātop left encoder not foundā no matter which encoder is plugged into the top left port on the board?
What does it mean when āLED 2ā is flashing red?
That means that when the board boots up it didnāt pass self test (couldnāt find one of the motors or encoders) and so it wonāt do anything until that is fixed and it gets restarted.
I feel like weāve maybe got too many threads going and itās hard to keep track of the conversation. Lets try to keep it in one spot and focus on getting to the answer.
I think weāre making progress here. Is this the case?
This is happening as soon as the machine powers up or only while cutting?
yes I tried plugging it into another one and it still said the same thing
Since @Caleb_Yager started this thread about his issue letās keep this one about him.
It says exactly the same thing as in:
Not a similar looking message that says āBottom right encoder is not foundā?
The distinction is important because it will tell us if the issue is on the encoder side or the controller side
