Why add to the measured dimensions?
I wanted to make sure to have enough belt but no to much. Should I just do the actual measurements??
Jeremy
Yup, it’ll add a bit extra for you
@bar Sir you are correct
, V.071 was great! This is the farthest I have ever gotten.
Is a fitness of .5132 any good? Will it get better if I run calibration again?
Jeremy
0.5 is decent, but it should get even better if you run it again.
The real test of how good the calibration is is to use the arrow buttons to move around and see how the tension in the belts feels
Very good, I will try it again. My problem earlier in this post happened again. Had to run that self reset file you sent me.
Does it have to do with this message I get when I first start up? What should you choose here or just ignore it?
You should be able to just close that window, but I wouldn’t expect it to be open when you first connect
