In this frame there just aren’t that many places you need to do this.
If you are trying to do bolts for the top beam supports, they need to be at as close to a 90 degree angle as possible, and even more importantly, the same on both sides. Bolts 2 inches apart are just not going to be accurate enough (the little amount of error you get in each bolt hole will multiply out the length of the part)
The only other place that needs a bolt is the top of the legs, and that can accept some error.
you are worrying about the wrong area, at the outer edges, the chain angle gets up to 80 degress (10 from vertical, so an included angle of 20 degrees), the side force available there is small.
This is why going to a 12’ top beam is expected to improve things noticably, but 10’ is already pretty big, and it looks like we are getting close to ‘good enough’ accuracy now, so the ‘stock’ design will probably remain at 10’ wide
I’ve started a wiki page so that we can tweak the assembly guide without huge walls of text here
slight tweak in the ordering, step 1 is attach lower blocks (opposite side of the kickers), same process as the kickers, but without the need to raise things from the ground
I’m late to the party here. Robotics season is upon us, so even though our Maslow kit has arrived, assembly of it will have to wait until we get our robot built. But before build season started, we did finish our frame with panel saw. So I’m gonna use this thread to show it off. It’s my “alternate frame design” which I posted quite some time ago. The panel saw sled was cobbled together with whatever hardware was around, so it’s not the most refined design, but it’s solid. The counterweights aren’t installed in the picture.
Building robots means you have lots of bearings to work with. We happened to have some that were just slightly smaller in diameter that the interior width of the unistrut. The round things you see at the top are just fender washers to keep the counterweight cables from slipping off their bushings. I haven’t noticed any sag even with the weighty sled.
unistrut has roller trucks that are designed to hang from the strut and roll, so if you put the slot on the bottom, you can use those (just find a way for your track saw to not interfere with the slack chain)
thinking about the panel saw, it doesn’t need to have rollers, something that just hooks over the top beam would work. I’ll do up a CAD of it after I finish doing the assembly step diagrams
Just a thought when you are figuring out a list of what a somebody would need for lengths of 2x4’s if you double the length the price is over double.
Here is a list from Menards.
8’ $2.98, 10’ $3.95, 12’ $4.98, 14’ $5.29, and 16’ $6.89.
If you could get stud length.
92 5/8 $2.75, 104 5/8 $3.19, and 116 5/8 $4.49.
There is also the problem of not everybody having a vehicle that can handle long loard lengths.
I discovered that onshape has an option to export all sheets in one file in dxf/dwg please check if you can use these Maslow Assembly Steps.dxf (91.4 KB)
Tried importing into visio and only got one sheet (and by size of file, likely just one sheet was exported) Title block was messed up and everything was line segments, so trying to color wouldn’t work. Still thinking on how best to do it… You can’t put fasteners into onshape, correct?
