šŸŒž New Stock Frame Design šŸŒž
I think we need something people can use to keep the work piece flat.
screw/clamp/nail to the plywood
I like @dlang’s design, but maybe with three A-frames (two near out edge and one in the middle)
remember that my design has a horzontal 2x4 across the top of the plywood, and
it’s trivial to add some blocks (or scraps of plywood) across the bottom. The
back of the plywood and the back of the bottom brace are flush with each other.
Can I also suggest that we incorporate a place to mount the electronics? like a cut piece of plywood that the boards can get mounted to?
I would put this under the top of the frame in the center (unless someone else
has a better idea), can it just attach to the bottom of the 2x4 or is more space
needed? (and if so, how much)
It depends on the frame design.
With the alternate1 frame above (with the fixed A frames), the plywood is
structure as there is not enough else controlling the A frames. switching from
2x4 to unistrut would not help (and may even hurt, bolts make great pivot
points)
I would strongly recommend against using unistrut for the bottom beam, you
want something there that won’t wreck you bit if you cut to low and get into it.
It’s a lot better to replace a $5 2x4 that gets chewed up a bit than a more
expensive bit that sends parts all over your shop
Here is a sketch of my basic idea. My representation is gorked on scale.
David, perhaps you or anyone else could onshape this. if we could design a
2x4 to Unistrut mounting cap. It could be easy to put together and take apart
quickly.
That’s pretty easy to do. Especially if you plan for the top beam to move
forward and back, it should be easy to remove entirely
The design is based on making the Skirt out of 9 inch boarders cut
from a single 4 x 8 sheet first. Using 2x4 small pieces of 2x4 to hold the
skirt edges together. This frame creates a negative space to mount the
ā€œworking sheetā€.
you need to adjust the skirts in and out to match your workpiece + wasteboard,
how would you adjust that? (also, you should only need 4-6", not 9" all around)
The 2 2x4’s 46 inches apart create the ā€œWorking Sheetā€ main
attachment. Two 46 inch braces between the uprights at the outer edges of the
skirts. The Unistrut sits on top of that. A diagonal brace between the 2
upright 2x4’s support it’s not racking.
thanks for the reminder, I didn’t include a diagnal brace on mine
1 more 2x4 as a ā€œlegā€ to tilt back on.
I don’t like a single leg, too tippy, and too easy to bend to the side
The motors are on a 12 foot long Unistrut 21 inches above the working top edge - ~7 foot 9 inches tall.
that’s 93 inches, normal doors are 80, garage doors are commonly 7’ (84")
now, you should be able to bring the top beam down, the stock design has the
motors ~18" above the top of the workpiece
By the way, I hope I’m not coming off as someone pitching their own design at the expense of others. I have put a lot of time in it, and I think it’s a very solid contender for the new stock design, but I want to be sure that I’m providing constructive feedback, not running down other designs.
Should not be tippy -
http://www.geom.uiuc.edu/~wanous/part3.html
any 3 points in the same plane are always stable - Yes it is less conventional.
David - I always appreciate your input and always find you constructive.
This is helpful and the bottom ā€œclearanceā€ is variable too.
They are stable as long as the center of gravity is within the triangle.
three legs make it easier for the CG to get outside of that footprint.
I’ve knocked over far too many easels over the years, or hung things from them
in ways that made them tilt.
The other problem is the question of the hinge, a single leg is much easier to
push sideways than a pair of legs (and the distortion of the support is much
higher)
I was trying to express the need to make sure the plywood is very flat and doesn’t warp or cup. That way when someone clamps/screws/nails a work piece to it, its also flat.
I don’t see a 2x4 spanning the top of the plywood sheet in your drawings. (I did not open it on onshape… just looked at what you posted.) The bottom can be handled as you said by blocks/scraps across the bottom. Just didn’t see one up top.
I’m doing something very similiar for my ā€˜hangs and folds flat against the wall’ planned setup, only I doubled the top 2x4 (and with that I’m getting maybe an ~.125" deflection with a 200+ lbs unsupported in the middle, which I reckon exceeds the amount of force the motors can supply at max torque) because I already had and it’s cheaper than Unistrut. I’m extending the vertical 2x4 arms up behind the beam and running a 1/4-20 lag through both; that way I can tighten it all down, or loosen it and put spacers behind it to push it out for thicker material.
My question is how much clearance do you have under the top beam support arms in your design when the chain is at the top of the opposite corner? I haven’t done the math, but preliminary playing around makes me think it’s at least 9" (I’m planning on making the support arms as plywood gussets on either side of the 2x4 uprights), but wanted a sanity check.
Unistrut isn’t available in home depot equivalents over here, i don’t know about the rest of Europe, but the first time i heard about it was when i was working as an elektrician in a seaport.
I wouldn’t make it required in the stock build. It’s a lot more expensive then a 2x4 over here if you manage to fibd it over here too.
I loved working with it though, when i didn’t have to pay for it.
Maybe incorporate an option to replace top wood beam with unistrut and everything else being standard? So if someone wants to take the extra steps and can readily get the materials, they could. I only suggest because it seems that the top beam is the most important part of the build.
⁣Sent from BlueMail ​
I agree it should not be a requirement, and it isn’t.
The motor mounts are a little harder to attach to to unistrut, so the 'standard’
design should probably be with wood, and as an option, use unistrut.
you want the motors ~8 inches above and 1-2 feet out from the edge of the
plywood to give you the right angles.
you want the chain attached to the balance point of the sled, and flat to the
workpiece.
Is this what you are asking?
Not really, sorry if i wasn’t clear. I’m asking how much room you have under this support before chain angle becomes an issue:
Especially once you tack a brace on:
If that’s 16" to begin with, would the chains clear the brace if the sled is at the top of the opposite corner?
The motor mounts can be attached to a piece of wood attached to the unistrut. That’s what I’m using presently.
@dlang, you extended your a-frame to the reach the top bar. Is this necessary? I don’t see how to easily incorporate a 2x4 extending across the top of the plywood and yet stay flush with the a-frame. Can only the back leg of the a-frame be extended up (i.e., does it provide enough stiffness to handle the stresses?) Something like this:
Drawing1
Alternatively, can we incorporate a gap in the front leg of the a-frame for the top plywood stiffener to fit into as shown below? It’s a bit more of a complicated build. I hope the picture relays the question.
Drawing2
I’m not thrilled with the alternative, which is to add a beam above the top of the plywood as it is done on the bottom of the plywood because if someone has a workpiece slightly taller than 4-foot, they’d have to trim it to fit it.
This is why I thought three legs (two near the edges and one near the middle) would give enough mounting points to ensure the base plywood is flat.
@madgrizzle
the top beam needs to be in the plane of the workpiece, so it can’t be supported by the back legs, it needs to be supported by the front legs.
the A-frame version doesn’t include a stiffener, the folding version does (it’s hard to see in those angles, obvious to me since I know what’s there, but not so obvious otherwise)
good point, that’s ~33 inches out from the brace, so that could be an issue (especially when not out all the way). let me tinker a bit.
The first thing to do is to pull the brace back, but it may be necessary to go with something thinner (put the 2x4 on it’s side??) to have everything clear.
The stiffener on the folding version just spans between the two legs? If so, same could be done for the a-frame, correct? and is that enough and that we don’t need to worry about the edges (though bottom edge can be fully braced)
