There is also FreeCad that can do CAD & CAM to export gcode.
The basic Maslow system setup is:
The Arduino Controller that is on the Malsow machine and connected to the motors. That has firmware updates which are available here: GitHub - MaslowCNC/Firmware: Maslow Firmware
You then have a computer or RaspberryPi that runs the Control User Interface and connects to Arduino Controller using the USB cable. You open your gcode file using this and run the cuts. That can use software:
- WebControl (recommended) - GitHub - WebControlCNC/WebControl: Web-based Ground Control
OR - GroundControl - GitHub - MaslowCNC/GroundControl: This is the Ground Control software used to control the Maslow CNC Machine
You upload your gcode files to these and it controls the cutting process.
Finally you have your CAD/CAM software of which there are many options (such as FreeCAD [offline], Fusion360 [requires internet], estlCAM etc). This is not provided my Maslow and must export Maslow compatible gcode.
I am currently learning FreeCAD as a replacement for Fusion360 but CAD/CAM software often changes dramatically in UI and workflow between companies so is often difficult to learn.
