New Torx screw replacements
Now that the weather is improving, I am going to make some time to remove some screws from my manually upgraded almost-Maslow 4.1, open the spools and install the new belt guards that I 3D printed. The last time I opened it up, I stripped a bunch of those hex screws, and I have screw extractors for when that will inevitably happen again. This time around, I want to replace all hex screws I remove with Torx screws, but I want to make sure I get the right ones.
90991A115_18-8 Stainless Steel Button Head Torx Screws.pdf (149.3 KB)
Does the attached description look like the correct screw?
that looks right to me, but I would consider getting 16mm instead of 12mm long
screws.
There are a couple of places that the 16mm will be too long for, but most places
have pleanty of space and the extra length will better engage with the nylock
portion of the nut.
