Hi, I tried for the first time to use my maslow (original kit + ring) and I could not get the automatic calibration to work. I received the error:
The machine was not able to be calibrated. Please ensure the work area dimensions are correct and try again.
After checking (they were the size of a 4 x 8 sheet of plywood) it still gave the same results. The test cuts looked fine and were vertical.
Because I wanted to start cutting, I ran a manual calibration and started cutting and cut out what looks to be a good sled, but I want to achieve decent accuracy so I am not sure what the next step is. I am hoping I don’t have to remove the chains and start over from square one. I have attached some screen shots and included my groundcontrol.ini file.
My frame is bar’s bolt together with a 10’ beam, latest firmware, latest ground control, and the original bungees.
I used the makermade instructions to construct my system because it uses a ring also and the original calibration said it was happy (where you put the chain between the two motors).
Any help would be greatly appreciated!
groundcontrol.ini (1.6 KB)
