My machine axis quit working. Mach3 shows them moving. Anyone have any suggestions?
X,Y,Z nothing works. I am using a UC100 . Machine worked great, I had to break it down when we moved and now nothing works
Sounds like a board or power supply problem. Do you have the power supply plugged into the right power port. Both the Maslow and Arduino boards have connectors. The power supply should be plugged into the Maslow connector. I hope this helps.
The Maslow can not be run with Mach3. Need to know more about the movement report.
Not a component of a Maslow.
