OG Maslow Cuts a Playtech Bike Rack right to edges
I dusted off the OG Maslow to cut some bike racks for some friends.
I was a little worried because the file cuts to every edge, but the Maslow looks like it did an amazing job.
To get an idea of the procedure:
  1. They sent me the svg file
  2. I imported it into inventables
  3. I set the depth for all the cuts and added tabs so it wouldn’t fall in on itself as it was being cut out.
  4. The software created 171,429 lines of code to make the cuts.
  5. I copied and pasted the code into the cnc contolling software
  6. We put the 8’x4’ plywood sheet on the rack. I surrounded it as best I could so the sled would be supported at the edges.
  7. I pressed go and the machine started cutting. The software said it was supposed to take 22 hours. (The file was NOT optimized for CNC and I could have probably spent an hour up front cleaning it up to save 4 or 5 hours of cutting)
  8. I installed a camera to monitor it while I wasn’t in the room. (I think I had three or four error messages that made me reboot during the 171,429 lines of G-code that I keep starting and stopping. But once I remembered how to get through that, it worked amazingly well.)
  9. I kept stopping it when I wasn’t close by and starting it back up where it left off when I could monitor it.
We started Saturday and it was done today.
Dust collection was absolutely horrible, though.
I think I’m going to keep the OG Maslow for big projects until it jumps a sprocket and build a small frame, portable , horizontal frame for the Maslow 4 if I ever get it working.
Original File
After Day 2
Day 2
After Day 3
After Day 4
Day 4
All done
That looks fantastic! Great work!
