I had some scrap plywood left over from the lamp project that was taking up space in my garage so I decided to make some plant stands.
I also used it as a chance to test using a roundover bit to round the edges on parts after cutting them out. I had done that before but only using a router table and I wanted to see how easy it was to do by hand (very easy).
The whole thing is a parametric model in Abundance which lets you set the parameters you want and will give you gcode ready to cut along with a .stl file for the 3D printed parts.
Check it out here:
https://abundance.maslowcnc.com/run/BarbourSmith/Parametric_Plant_Stand
