When cutting, does the plywood need held down with something so it doesn’t move around? If not, what happens when the piece is finally cut from the ply, does it drop down?
A) I screw my stock to the waste board, B) you can screw the product to the waste board too, C) you should have tabs so nothing “Flies Free”. Free high velocity spinning stock floating thought space is dangerous!
PS. Also don’t be on Fire!
some people use plastic finishing nails.
