Have not been able to compile firmware from the beginning. I get the following error;
In file included from Encoder.cpp:2:0:
Encoder.h:41:37: fatal error: utility/direct_pin_read.h: No such file or directory
#include <utility/direct_pin_read.h>
compilation terminated.
The utility directory is included in the same location as the cnc_ctrl_v1.ino file in “sketchbook/libraries/Firmware/cnc_ctrl_v1/” . is there an issue with the file path here or is there some other step I need to take with Arduino to find the utility folder? I was able to include the full path to “utility/direct_pin_read.h” in “Encoder.h” where these header files are contained, but then encounter multiple other functional issues preventing compiling including attachInterrup being duplicately used as a macro with 2 parameters and a function with 3. Any help you can offer would be appreciated.
