Raspberry Pi GC Connection Lost error
Ground Control runs fine on my mac, but I am running into an error when I try to run GC on my Raspberry Pi 3. I am connecting to /dev/ttyACM0. I have even ‘chmod ugo+wrx /dev/ttyACM0’.
I get messages that i am “Connected”, but then Connection timed out and i get “Connection Lost”.
The GC console says that Pyserial version 3.x is needed. version 2.6 is installed.
any suggestions?
Here are the project docs -
http://pyserial.readthedocs.io/en/latest/pyserial.html
Discussion -
https://www.raspberrypi.org/forums/viewtopic.php?t=38360
It’s going to depend on your version of Python
1 more -
sudo pip install --upgrade pyserial <---- fixed my problem. Now on to building my frame and getting everything up and running. Thanks a ton.
You are most welcome.
you might want to see the reading list here:
May the force be with you. I’m trying to set up a Pi3 right now. I may have questions down the road about your Pi setup and experiences.
