MadGrizzle helped me the other day to set up my raspberry pi to run my 3D-printer, MPCNC and MaslowCNC from it.
Now that my ip-port issue is resolved I encountered a new port-issue. The drop-downlist in WebControl (Settings/Maslow Settings/Serial Connection) does not contain the COM-port I need and therefore my Maslow won’t move.
In CNCjs (which I use for my MPCNC) I can see and select both COM-ports (MaslowCNC (ttyACM1) and MPCNC (ttyACM0)), but in WebControl I can’t see them. The only COM-ports I can select in WebControl are ttyAMA0 and ttyprintk.
Is there a way to manually input the correct COM-port? Or is there another solution to my issue?
The code to refresh the list uses built in Linux routine to determine available ports. Is there a chance that the port is still in use by some other software?
