I’ve set up a wiki page for different materials here:
Hopefully folks will add in some successful rates and results and we can get some standard ‘feeds and speeds’ together for the most common work materials.
I know Bar has reported using ~20-25ipm rates (bit type unknown) and the ‘top speed’ is reported as 45ipm, but the machine doesn’t corner well that fast.
As for cutting depths, i think conservative numbers = bit radius per pass, no more.
I’ve been pretty much running everything at 30 ipm with a .15 step down these days, but you can be more aggressive than that for sure. I think I leave the plunge rate at 30 ipm, but the firmware will limit it to make sure it can keep up.
one of the biggest complaints on the ‘tested’ video is how slow the machine is.
It would be really useful to have someone do a bit of experimentation with
’normal’ 3/4 plywood and test how aggressive the cutting can be (both in depth
and in speed). It would be useful to test both in the bottom corners, and nearer
the center of the sheet.
I think that the tested video was shot at 10ipm with a .1 inch step down so what took “about 20 minutes” in the video would probably be more like 4-5 minutes with the pretty conservative settings I normally run now. We only had one chance to have eveything work for that video so I was VERY conservative
Out of curiosity, does being very conservative on z depth and thus number of passes increase accuracy? Obviously super aggressive passes at over 1/4" will cause drag and unpredictability, but at a certain point more passes just means more potential minor deviations at various depths as each pass isn’t repeated identically right? It seems like under .1" and not only is it slow, but could actually be less accurate? Or is more passes always better?
I’ve read that some CNC type machines “slow down” for corners, and then speed back up. Any thoughts of including speed changes when approaching a corner (of course defining a corner vs a curve may be interesting).
I’ve researched it as an option that I can set in Fusion360 but I still don’t have a MaslowCNC (or any practical CNC experience for that matter).
I would guess that the 2 ways to approach it are:
CAM software just building it in as a function of its .nc file generation, prior to any CNC machine compensation of the intent of a given machine path. In the case of Fusion360, there was mention of Autocad-HQ being near Maslow-HQ and some form of active communication that might result in a MaslowCNC specific post processor, which i assume would do similar things as #2.
Ground Control interpreting the Gcode and applying some sort of processing to compensate for how the machine would actually respond to those raw commands. (by being aware of ‘slew’ or ‘sag’ (my terms) or degrees of accuracy and other MaslowCNC-specific machine constraints)
Acceleration, jerk, and higher order rate of speed change parameters are what you’re describing (look at grbl, Marlin, tinyg, Auggie, Mach3/4, LinuxCNC etc). At least LinuxCNC implements full stop mode between segments too.
With luck Maslow is following the 3D printer firmware trajectory. No acceleration, add acceleration and jerk (which gets you higher speed/better cut quality), and maybe the higher order parameters like snap, crackle, and pop. With the odd kinematics Bar started from scratch so it’s not surprising the harder stuff got left for later, and/or future more powerful controllers.
It’ll be a fun project. Now if I wasn’t cutting 40 cords of firewood, fending off swamp rats, and still pulling medic shifts…
The proper thing is for the maslow to know the rate that it can change direction
and speed reliably and then when told ‘move from here to there, then turn and go
to that point’ it would know how fast it can be going when it needs to turn.
the grbl code has a very good planning section in it that accounts for this sort
of thing. Once we get the accuracy worked out, we can copy that code.
that’s what needs to be tested. Early on Bar made a test where he cut all the
way though 3/4 plywood in a single pass at the fastest speed he could get the
machine to move. He was concerned about breaking the bit at that speed, but if
that really is a problem, moving to a larger bit would probably solve it.
We need to have people test this sort of thing and report the results.
The thing I’m most excited about exploring is cutting very aggressively but a little outside the line, then coming back for a “finishing” pass. That way the accuracy doesn’t really matter, except on that final pass where not much work is being done.
Integrating G-code generation into Ground Control would let us automate a lot of these things.
As long as the inaccuracy is away from the final part.
Roughing and finish cuts are a common thing, but you know that already . Just what does it take to break a 3/16 or 1/4" carbide bit? Precisebits.com has a max feedrate test procedure, basically increase speed until either the quality is unacceptable or the bit breaks, but they’re in the bit selling business.
while I see the attraction of trying to simplify things, please don’t reinvent
the wheel. There are a lot of tools already available that will create the
g-code, and they all have strenths and weaknesses. Yet-another-tool for this
isn’t nearly as valuable as making the firmware for the maslow work better
(faster, add acceleration/planning features, etc) that will help everyone no
matter what generated the g-code.
I don’t want to be limited to using Ground Control any more than I want to be
limited to using Fusion360. The Maslow should consume g-code no matter where
it’s generated.
Once you start down the road of generating the g-code, you then want to tweak
what you are generating, which quickly turns into making another CAD program.
