Hey all,
I’m just getting my machine up and running again after installing the upgrade kit, and I have a question about the proper workflow for releasing and reapplying tension.
I like to release the tension when the machine is not in use and hang if from a bungie cord so that the belts are all slack. However, after I release the tension, the machine won’t reapply tension properly. I end up having to detach the belts, retract them, and then extend again—which takes extra time.
Is it expected that I should be able to release tension and then reapply it easily? Or is there a different process I should be following?
Thanks in advance!
