AEG is finally supplying the AEG MF1400KE router through Bunnings.
Welcome to our forum
Nice one
@Dooz have you used the AEG? STILL $400 though, I wonder how it compares to the triton that @Firewuff is using? Any ideas?
Not sure sorry, I still haven’t set my Maslow up. However I like the 6 year warranty on the AEG.
At that sort of price, a c-beam/meticulus Z + a chinese spindle sounds like it
would be a clear win.
Hi all - not sure wheter this is the correct Topic for my 5 cents …
to use almmost any router - would the attached links “CNC z axis slide table” resove most issues regarding lifting the router / bit with this kind of attachment from bangggod - they have a few different sizes…
cheers Holger
That’s the right idea, but you would need to replace the stepper motor that is
included with that with a DC motor/encoder. Unfortunantly the firmware is not
able to drive a stepper motor (and the motor shields are not designed to drive
them either)
thank you David
…just started a few days ago showing my wife what i would like for my birthday…a Maslow Router Kit !
…and come across the australien forum regarding suitable routers…
…back to the forum/drawing board
cheers
Welcome to the Forum!
If you go the route of having a better Z-control, you might also consider a spindle.
They have a few other advantages, other then the price.
Kind regards, Gero
Who’s rig is that pictured @Gero?
My third temporary sled
500 Watt Spindle?
What is the use of second product? Is it a plate to fit this motor??
After all these things, can we joint on router table top?
Welcome to the Forum @Brown40,
If you are referring to my links, the second part is to move the spindle up and down on the Z-axis of the MaslowCNC. And no, the spindle clamp from the first link did not fit the plate on the c-beam. I had to modify it to make it work.
In theory it could work mounted under a router table, but there are better builds for this target. Also for a router table i would choose a router, rather than a spindle.
Kind regards, Gero
Hi guys,
As I’m new to this group I’m wondering what is the best solution for the router in Australia
Cheers
Hi Benji, are you still making these? How can I contact you privately?
