Hi, when I go thru calibration wizard a step ask to rotate sprocket so one tooth is at 12 o’clock or pointing straight up. But when I try to rotate it I hear a sound from the motors but the sprockets don’t turn. I have checked my connections from the motors to motor board. I have the motor board 12 v adapter connected
when i hit test motors, they correctly go up and then down
I have heard of others having the same issue, but I have not experienced it myself.
What happens if you use the “rotate 5 degrees” button several times, is there still no movement?
Does closing and re-opening Ground Control help? This issue has come up before, but it always goes away on it’s own before we can figure out what is going on.
