What thickness of plywood is everyone using for their sled? 1/2"? 3/4"?
Also, I know everyone typically uses plywood because it is cheap, but could I use plexiglass? I have a huge half inch thick sheet of plexiglass and I thought if I made the sled with it, it would help reduce friction on the plywood as it moves to cut.
I used 3/4 plywood, but I’ve seen a number of materials used. Someone did a Plexiglas one which was very cool because you could see through to what was being cut
@adamdj; I’d like to purchase one of your plexiglass sleds if you decide to make them. I’m convinced that some form of a plastic sled will ultimately be the best choice for Maslow …due to lower drag.
