Dear Maslow community members,
i’m new in cnc cutting and build the Maslow to cut testpieces for my WikiHouse project.
One of my big problems is that the sled tilts (see attached images).
Where did i make the mistake?
Is it because of a different size of the frame wood (i used 60 x 100 mm)?
Is the tilt of the frame wrong, so the sled cannot touch properly the working surface?
Just mount your ring higher on the L-brakets and the tilt will be better. You also will want your motors out the same distance to the workseet, or you will need chain guides to avoid jumping chains.
very thanks for the fast reply.
No, i mean really mm (see image).
I am not sure, if the difference measures of the wood makes a difference at the end.
So the dimensions of the frame aren’t right.
Just went through this on other thread Sled Balance
Main points were:
With the sled removed from maslow hang the sled using rope at the top of the metal ring. Instructions indicate that the sled should hang straight down. I found, on my sled, that having it tilt half the angle of the work surface worked better. Adjust the sled balance by moving the ring away/towards the sled base.
Mount the sled back on Maslow and check the angle of the chains relative to the work surface. They should be parallel. To fix this you can add another backing board to work surface or change the length of the spacer blocks that hold the top beam (that the motors are attached to). Wrong chain angle tilts the sled more when the chains are short (at top of work surface). If your motors are mounted too far away from the work surface then the top of the sled will be pulled away from the work surface. Conversely if the motor mounts are too close to work surface then the bottom of the sled will be pulled away from work surface.
sled base.
note that the Z position of the motor will affect this, as long as you are
pretty close it should work
work surface.
This affects the chain wanting to jump more than tilting the sled.
