Hi,
this is my first post here, as I’m just getting started with my Maslow 4.1. Yesterday I wanted to do my first cut, but it didn’t go well. Here’s what’s happend:
Setup: I have drilled holes into my concrete courtyard (roughly 3000x4000 mm) and installed 8mm bolts, because that’s what I had at hand. To prevent the belts from rubbing on the ground and collecting too much dirt, I added spacers to keep the ends of the belts about 20mm above the ground.
Calibration: I did that a few days ago and I think this went fine. Fitness 0.59, tlX=44, tlY=3229, trX=3850, trY=3179, blX=0, blY=0, brX=3830, brY=0. Unfortunately I haven’t saved all the serial output, so I can’t say anything about the stiffness measurement or other information printed during calibration. I guess that’s part of my learning curve …
Yesterday’s crash: Temperature was about freezing. I wrote a simple gcode file to move to the four corners of my part so that I could align my wood. Extend the belts, take up slack, Maslow says it is at -89, -5 (out of my memory, maybe there is a sign or coordinate flip, but that’s the numbers). Maslow jogs fine, I start my gcode and as Maslow approaches the first corner, I push “pause”. Maslow stops and loses network connectivity. I can’t reconnect, so finally I decide to power cycle Maslow. I’ve seen WiFi problems in cold conditions on ESP8266 and (less) on ESP32 before, and there is another thread here mentioning it: Communications and belt retraction issues on a cold day.
Anyways, after the power cycle Maslow reconnects to WiFi, so I do “release tension, take the belts off the anchors, retract belts, extend belts, put them back on the anchors, take up slack” (is this actually required after every power cycle?). Maslow reports “0,0,0” as position, which I find surprising, so I try to jog in y-direction. First time nothing happens, so I try jogging again. Now one belt snaps just a few mm from its anchor point.
After the belt had snapped, I realized that the bolt I used as anchor is now bent by ~30°. One other anchor bolt was also bent, but much less. I believe that this bending contributed to the snapping belt by causing much more tension on one side of the belt than on the other side, thus tearing it across its width rather than just pulling along the main direction of the belt.
Now I wonder:
- Did I underestimate Maslow’s pulling force and my 8mm bolts are too weak (especially as they are not supported at the top)? Do I need stronger anchors?
- Or does this sound like an issue with the belt tension measurement?
- Did the cold weather contribute?
- After the crash I also realized that Maslow complained about a “center point deviation (BL -13.2, BR 6.7)” when setting it up again after the power cycle. Was that the reason it didn’t want to jog? Were the bolt already bent after taking up the slack (they were still straight when I put the belts on)?
Thanks a lot,
Hendrik
