I had a belt break a couple of weeks back. Anna was kind enough to send a new one (thank you @anna
), but I haven’t had a chance to pick it up yet. My broken belt is now 8 ft long (I’d have to double check that). I put anchor points at proper spots to account for the broken belt and am now trying to calibrate with:
frame size: 2036 x 1370 (the distance from my anchor points)
workspace size: 900 x 629 (calculated from online tool)
grid size: 9 x 9 (I have tried 7 x 7 as well)
There doesn’t appear to be any flex in the frame, but I can’t get a fitness over 0.19. Would the shorter belt account for my issues?
I appreciate any input ![]()
Serial Messages
[MSG:INFO: FluidNC v0.75 (Maslow-Main-e2ef1bb2-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:ERR: Configuration file:maslow.yaml]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO:<Alarm|MPos:0.000,0.000,-106.000|FS:0,0|Ov:100,100,100>
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Smyk]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: No SSID]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Set to comply]
[MSG:INFO: Bottom Right pulled tight with offset -893.983]
[MSG:INFO: Top Right pulled tight with offset -1023.750]
[MSG:INFO: Top Left pulled tight with offset -1263.240]
[MSG:INFO: Bottom Left pulled tight with offset -1151.692]
[MSG:INFO: Center point deviation: TL: 0.094 TR: 0.172 BL: -22.534 BR: -18.231]
[MSG:ERR: Center point deviation over 15.000mmm, your coordinate system is not accurate, maybe try running calibration again?]
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: -0.016 TR: 0.084 BL: -21.860 BR: -17.340]
CLBM:[{bl:1206.20, br:1212.73, tr:1228.95, tl:1231.64},{bl:1185.95, br:1227.04, tr:1250.10, tl:1206.36},{bl:1090.98, br:1274.04, tr:1355.57, tl:1189.35},{bl:1129.85, br:1320.30, tr:1323.74, tl:1140.49},{bl:1175.90, br:1359.53, tr:1284.73, tl:1094.98},{bl:1235.16, br:1275.56, tr:1191.18, tl:1173.01},{bl:1352.49, br:1187.77, tr:1091.90, tl:1276.87},{bl:1322.84, br:1138.82, tr:1131.30, tl:1320.62},{bl:1283.82, br:1093.18, tr:1178.50, tl:1360.87},]
Computing… This may take several minutesFitness: 0.1941775 in 100
Fitness: 0.1941775 in 200
Fitness: 0.1941775 in 300
Fitness: 0.1941775 in 400
Fitness: 0.1941775 in 500
Fitness: 0.1941775 in 600
Fitness: 0.1941775 in 700
Fitness: 0.1941775 in 800
Fitness: 0.1941775 in 900
Fitness: 0.1941775 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
