Rigid Vacuum Attachment: Printed with Cura Experimental supports 25 infill on a raft.
vacumetest.stl (214.2 KB)
Z axis top bracket to deal with slop in Motor L bracket
if the rubber gear belt is slipping then just add some shim material between the motor bracked and aluminum z axis. a refrigerator magnet, scrap piece of plastic or sheet metal, etc. I assume that is why you made the purple piece that goes around the belt gear.
