I’m probably going to have to write this up in chunks rather than my usual monolithic style due to…life - so don’t be surprised when I miss big chunks in this first writeup.
Ok, so I’ve had this going on in the background for a number of months (to give you some idea, the green bits are from when I started on it, and they pre-date me buying the printers I’ve used for everything else you’ve seen from me…). Given the awesome discussion in the Next version of the maslow idea? an m8 I thought I should actually stick something up about it even though it’s barely at proof of concept stage, just to avoid anyone wasting duplicate effort.
What is it?
Basically, taking the arms off the Maslow and moving them to the corners. Replacing them at the centre with a set of interleaved rings to attach to:
Core
I guess the core of it is is the equal-height attachment points at the spindle:
This was the seed of it all for me really - I was mulling what you actually would have to do to get equal height for the attachment points, and moving the arms off the Maslow made the most sense. Then you have to work out how to get those equal heights. I figured the best was was a set of interleaving you can see there, with a bunch of washers between (it was what spawned the [PTFE washers for between arms](PTFE washers for between arms thread - ptfe was easier than getting custom washers made).
It’s not the easiest to explain in words so i’ll take more photos later, but in essence:
- 2 plates for opposite side with one washer between and a thicker attachment-point-area fors a 2mm-thick set for 2 arms that are opposite.
- We can offset 2 x 2 plates with spacers the same height as the belt end - then we have 2 opposite side assemblies with equal-height attachements.
- But if we then use an additional 2.5-3mm spacer alternated top/bottom of the attachment points, we can interleave a 2nd set of 2 x 2, to give us 4 bottom plates & 4 top plates, with 4 equal height attachment points, that also have the benefit of only taking up about 50mm height (which i’ll talk about in a sec.
The corners and wiring are their own whole things but I’ll add details later - they’re largely obvious.
Why? Advantages?
I’ll be honest, I did it because I was curious if I could. But it also offered some potential benefits I’m going to start exploring now I’ve had a working POC:
- As above you can get the attachment points all the same height - with all the benefits that brings.
- You can get a sub-5kg assembly - or given I’m working on a chunky-spindle build, I can offset some of the weight gain.
- I think you could run a higher speed lower torque set of motors and push feedrates higher: (hence this thread: Feedrate limits of the Maslow (theoretical).
- The less deep core means you can fit a Makita router easily, or have more control of the height of the bottom of a DeWalt router collet while still beefing up the clamps. It’s a bit blurry, but:
Drawbacks
Cost and complexity are obvious, but it also feels a bit…against the philospohy of the Maslow - it’s no longer a single unit you can (theoretically) plonk down on a sheet of material, hook up the corners to solid attachment points, calibrate and cut. In time, perhaps it can get to be a bit more like that but we’ll see.
The big one yet is i’ve not explored how long the wires can be before you hit issues. I deliberately am only doing the arm-motor and sensor wires rather than the Z-motor ones too because I think they are more resilient to longer wires (as the Z-stepper drivers are on the control board). But I have also only tested 2.5m wires, which give me 1mx1m, possibly 4ft*4ft with careful routing.
What have I managed so far?
A few simple logo test cuts - 3.175mm (1/8th) bit, 4 passes, 3.25 DOC each pass. Speed is…complicated. I did 1000, 1500, 2000, 2500 mm/m, but I believe I was acceleration limited at or above 2000mm/m - I am not claiming that as an actual speed. I saw a perceivable difference between 1500 and 2000 but not above. At that point I was also starting to see a little stuttering.
Next?
With those cuts, I am using a long O-flute single flute bit. I was getting ok-ish chips at speed 4 but it felt like hitting issues I can resolve. The bit is quite long, and the collect of the router is a little way off the top of the cut, so I think I might be seeing bit flex as I push it. I believe with some minor changes (to get the bottom of the collet down to just above the top of the cut) I can get a bit more stiffness in the bit and I can try pushing it a bit more. I want better chip ejection if I can, I think the O-flute isn’t doing me any favours, they are just the most easily available for me. I’m going to get hold of more spiral / open sided bits too.
Plus longer wires and testing it a bit more generally!
