A while ago I came across a video of someone using a brushless/cordless dewalt router in a gantry CNC, with one of those Ali-Express ‘Power your tool from the mains not the battery’ PSUs. Not sure if it was linked here or reddit or just a youtube recommendation.
I piqued my curiosity a bit, and I spent a bit of time looking at various things on Amazon, when I came across these two things:
and
(speciffically the 1kw version as it’s more PSU-like).
Why are they interesting? Well firstly, the router has a longer body than the usual makita clones, even the brushless ones:
In fact, with a shim to fit the regular clamp letting you get a little bit of depthe back fromt he chamfered area, it is only about a mm shy of being the right length:
Now i’ve not seen a brushless (or brushed in fact) makita-clone / budget router with a body comparable to the dewalts before, and the fact it’s brushless is particularly interesting as I want to try out a brushless router as a stepping stone to a big spindle.
The second interesting thing is the router + PSU together came in under a hundred pounds (so likely under a hundred dollars given the way tool prices are) - which sits somewhere between cheap brushed router and expensive spindle territory.
The current downside is i’m using a makita to dewalt adaptor and the power cord is only a metre or so:
one thing I’ve started doing is mounting the power supply to the towers. It’s not that hard to keep them clear of the arm swing and you can get it so that you only have one power cable back to the outside world.
I need to extend the wires, but I’m strongly considering it. I printed new
towers (that I won’t install for another week) that are stiffer and have a large
flat area to mount things to.
Got it installed into my I linear rails-ed my Maslow Maslow (videos in there), after converting it to an over-the-top DC plug connection.
Will have to see over time as i’m trying to push what works with that setup, but it handled 6mm cuts in softwood ply with a 6mm single flute upcut bit at 800mm/s with no problem.
The brushless router, the way I’ve done the cord or the Maslow modifications?
I bought myself a brushless Dewalt that I use with the battery adaptor PSU - I generally use the Dewalt as it is definitely stronger than the cheap one, and widely available. That said the cheap one is lighter and can handle 1/8th bits cutting 1/8th passes just fine (in plywood), not sure on the longevity but it seemed ok
I’m happy with the brushless routers and will keep going with them - I am hesitant to suggest anyone else to do so though, because it’s very much using them out of spec and who knows how safe it is (I know I never leave anything unattended, have good cutout switches and fire extinguisher on hand so I am happy I can use it safely, but couldn’t guarantee it’s a good idea for someone else).
