Is there a way to get ground control to start on a specific line of the g code? I was 75% done and accidentally hit stop instead of pause
On what operating system are you running?
Edit: If you did not do anything else, there could be a chance to find the line number in the log.
try this
GC looks a little different.
If you know the line you can use the goto button at the bottom.
How did I miss this
I’m running ground control v1.00
Do I put the line number in the go to button?
you click on it, it will open a dailog to enter a number
Which number? Line number. Or x - y coordinate?
line number is waht I looks like - it’s labled -goto gcode line in 1.02
There’s a 1.02 now? Lol
are you on windows 10?
It’s an older computer. I’m 99% sure it’s windows 8
Putting the line number in the go to button worked.
Glad you’re good to go.
Thanks for the help
That engraving is beautiful! I’m glad you found a solution
Another option if you don’t know the line number is to use the fast forward buttons to “fast forwards” to where you left off
The 1> button will take you to the next line, and the Z> button will take you to the next time the z-axis moves. I’m working on a change for version 1.03 which will highlight the next line of gcode in green so that it’s even easier to see exactly where on the cut you are fast forwarding to
